little battery cover switch.
Hello,
my 650D could no longer turn on.
I found on the Internet a note that it could be the battery cover switch (little secure switch when you open the battery-cover). As I pressed the little switch with the screwdriver the eos turned on. :D
In the Internet I was supposed to bend the small switch with the screw in the middle. At the attempt the switch broked : /
Now my questions:
Can this switch or the board be replaced?
If so, what is the description of this board-part?
Can you simply bridge it? (I can solder)
I would like to unscrew the camera when I know more about it.
Thank you.
Это хороший вопрос?
