does the A1052 support 1Tb hard drive
Does the A1052 support support 1Tb drive?
Это хороший вопрос?
Это хороший вопрос?
Here's how to do it but it uses and ATA drive not an SATA and I don't know where you can find such a drive. It will however, that the 12 mm thick drive.
Search for a ATA100 (IDE) 5400RPM Hard Drive or better
Here's a PDF on doing it:
http://web.archive.org/web/2007011803443...
here's the standard guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Был ли этот ответ полезен?
Will the A1052 support an external SATA drive that I can use as a startup drive?
Sure if the connection is a USB to SATA.
Pre-Installed MacOS: X 10.2.7 Maximum MacOS: X 10.5.8
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 84
