The fourth-generation Surface Pro tablet, released October 26th, 2015.
208вопросов Показать все
Microsoft surface pro 4 mother board schematic help
i need the motherboard schematic for my Microsoft surface pro 4, i7
Это хороший вопрос?
Оценка 4
4 Комментариев:
Hi suface not poweron iwant shcmatice
из
Hello i need too surface pro 4 schematic (datasheet) you found?
из
hi, could you make it 16gb ram? i have a surface pro 4 and i wanna replace the rams. how did you do that? did you need to replace resistors?
из
Hello,
Unfortunately I haven' t got the schematic. Also for surface 1 they were not available.
But if anybody have got them, I would also take them.
But I' ve also got another question.
Is your surface fitted with 8 or 16gb of ram?
I ask because I want to upgrade my Ram from 4 to 16gb and I also ordered the necessary chips already.
These are K4EBE304EB-EGCF ones from Samsung.
But now I'm not sure whether it is necessary to equip also the marked areas in the pictures with components.
https://picload.org/view/dgrpgrdr/pictur...
https://picload.org/view/dgrpgrda/pictur...
Now my question for you is the following. If you have removed your mainboard, could you please take a look at the marked free areas in the picture and check if there are any components are mounted. And if there are should be any maybe you could take a picture or tell me what' s there because there are absolutely no pictures in the inernet.
Thank you very much for your help.
из
Добавить комментарий
1 ответ
I have it, write to my email and I will send it to you. manuelbrito162@gmail.com
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Bashar Aljawrneh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 12
За всё время: 3,408
