Is my sd card slot broken?
Says can't use this memory card. Menu skips right over format card option.
Says there is a card in when there isn't.
Это хороший вопрос?
Это хороший вопрос?
@jsd9086 it is possible that the card reader thinks a card is inserted due to a bend or stuck switch. Your reader will have one tab that gets moved away when you insert a new card and thus recognizes that. If that tab is no longer working properly, your camera will be told that a card is inserted. Of course, you also should try a different memory card. Use these guides to work on your camera
Был ли этот ответ полезен?
Thank you oldturkey03
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 126
