The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262вопросов Показать все
My DSi flashes both screens for a split second, then shuts off
ok so (deep breath)
2 years ago, i bought a pre-owned blue dsi. it worked just fine, but last week i was on flipnote studio late in the night and i was very tired. so i made the ever-so-wise decision to just leave it on overnight, because as we all know leaving a dsi on overnight with its charger on is a good decision. anyway, next morning i wake up to find my dsi off. 'strange,' i thought. 'i don't remember ever turning it off.' so then i tried turning it on and it flashed for a split second, then shut down. i was like, 'ok, maybe my charger fell out overnight or something,' so i decided to charge it. it only charged for maybe a few minutes before stopping. 'that's strange,' i said. 'shouldn't it have stayed on for longer than that?' so i tried turning it on again. no such luck. i went online and read that it could be the power board causing this, but i'm not sure i have the right tools to go investigate, as i've only gotten the battery casing off at this point. i'm not sure what to do now, so if anyone could help, that'd be awesome.
(tl;dr left dsi on overnight, next morning flashed screens and didn't turn on)
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi, Matt.
I will try to help you with this problem of yours. Did anything change after taking out the battery and reinserting it - have you tried turning it on while plugged in without the battery installed?
If not, you'll have to crack that console open and see if there's anything wrong with the motherboard or powerboard. Look for burnt things or missing fuses at this point.
Nintendo DSi Motherboard Replacement
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
it still happened
из
Добавьте свой ответ
Matt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 175
