Repair and troubleshooting information for the Barnes & Noble Nook HD+, a 9" screen e-reader and tablet released in November 2012.
Tablet dead, can I use it as a display?
My Nook HD+ has been dead for some time. I think it should be something with the mother board. The display is still nice, no dead pixels.
I've been thinking if I can convert it to an HDMI display? where can I find those connectors for the display and how should I wire it to HDMI cable? And Can I make use of the original speaker on it, too?
Thank you for any suggestions.
Это хороший вопрос?
Счет 1
1 Комментарий
acturally it’s still working. I found another post on xda about the Nook’s battery then reset it. (actually charged it via an USB port on PC). It came back. but now it’s too old and slow. I can still play some very old non-graphic intensive games there, but I have a much better 10 inch tablet now. Such a waste of screen.
Also, on ebay and aliexpress, there is no board for this screen. It’s probably a very small batch and not sold to other manuractures. Can’t adapt to universal use. And there are 2nd screen apps now, which won’t work on Nook right now .
Such a pity can’t make use of the screen.
из
Добавить комментарий
1 ответ
Выбранное решение
@raydashu you can only do that if you can identify who the maker of the LCD panel is and what model it is. Then you need to get the datasheet for the panel to determine the proper wiring/connector. After that you will need to either build a driver for that or try the many places on ebay the sell universal LED drivers. This will be a difficult undertaking since you have to get the proper information for the panel.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thank you. seems I'd better find a dedicated display. To much work for it and maybe even more cost to it.
из
@raydashu smart idea;-) Maybe sell the display as a repair part. If it is in good condition you should get some money back from it and might help out somebody else :-)
из
Добавьте свой ответ
Ray буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 1,431
