Smartphone designed by Xiaomi in the Redmi Note line.
56вопросов Показать все
Broken screen. Do I need both digitizer and screen?
Hi,
I broke my Xiaomi Redmi Note 4X 5.5 Inch screen.
I have found this guide: Xiaomi Mi Note Screen Replacement
I am not sure though, if I need both a screen and a digitizer.
Despite the crack on the screen, the phone works fine it terms of functionality.
Image is here, happy to also add a video if it helps:
Any ideas/help?
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
Наиболее полезный ответ
You only need the screen. But this process is really hard therefore you will probably end up breaking the digitalizer during the repair if you have not tried it before and then you will also have to replace the digitizer
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
thak you buddy. I went ahead and ordered both.
Taking them apart sounds one bit too complicated.
из
Добавьте свой ответ
Speaker Stelios будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 4,583
