AF-P 18-55 lens autofocus issue
The lens suddenly stopped auto focusing. What may be the issue ? The camera is autofocusing with other lens but not this one. I have tried to clean it and re attach it but the problem persists.
Это хороший вопрос?
Это хороший вопрос?
There seems to be an issue in the lens, since you have said you had other lenses that work (assuming they are also AF-P). Could see if the connectors are working correctly and are clean (check the camera’s as well).
Does the manual focus work at all? The AF-P lenses use a fly-by-wire system for the manual focusing, so if that does work, then it is likely the camera and/or lens has manual focus set, and the lens is communicationg to and from the camera, and the focus motor is working.
Был ли этот ответ полезен?
Same problem with my D5500 as well. It do not auto-focus
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 1,208
