Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104вопросов Показать все
Disk trapped in DVD drive
Hello,
I have an old iMac EMC 2266. Somehow, 2 DVDs were inserted into the drive. I managed to get one out but the other is stuck inside and has been for months.
I should mention that I have attempted all of the helpful force eject strategies including trying to force eject from the terminal.
I am wondering if there is a way to disable the drive permanently so I do not have to listen to the disk trapped inside trying to play or eject. I should mention there is no disk visible on the desktop or disk utility.
Any suggestions would be great. I would really prefer not having to open this thing up if possible.
Peter
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
FIRST: it will sound funny, but it helped me in the past... lean the iMac with the super drive hole facing down (gravity might help) while executing de terminal force eject command.... if it doesn't work then:
Why not disconnect it from the logic board?? in that kind of iMac, is not a big pain if done with careful =)
iMac Intel 20" EMC 2266 Optical Drive Data Cable Replacement
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Peter O будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 45
