The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
darlenebarber54 @darlenebarber54
Опубликовано: 26 сен 2017 г.
will not print from computer
Это хороший вопрос?
5 Комментариев:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
26 сен 2017 г. из jayeff
Printerhead? what do you mean? or are you trying only to print from your pc?
26 сен 2017 г. из jbermudez27
Yes. It is not printing from computer or copy or fax
17 янв 2018 г. из lorenzo.walker
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
17 янв 2018 г. из jayeff
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 61
Hi,
из jayeff
из jbermudez27
из lorenzo.walker
Hello jayeff,
из lorenzo.walker
Hi lorenzo.walker,
из jayeff
