Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
68вопросов Показать все
Changing LCD and touch
My Samsung J7 pro has a broken LCD. When repairing do they have to change the touch too? And they say that they will change the body too. Is that necessary? And please post a video on how to fux Lcd screen because I want to try to do it myself
Это хороший вопрос?
Оценка 2
1 Комментарий
I change the whole LCD of my Samsung j7 pro, at first its ok it turn on then suddenly black out. I used another new LCD but now it doesn't turn on, there is a sound but the new lcd does not have a power? what else should I check?
из
Добавить комментарий
2 Ответов
Выбранное решение
https://www.youtube.com/watch?v=xL0U6zVr...
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thank u so much
из
not a problem
из
I replaced the lcd already .. after 1 week of using.. it suddenly stop and the screen become blank.. . wat should i do? Thanku for the response☺
из
I had my lcd replaced it cost me P5,500 from a repair store. At first the technician said that i need to use the lcd that he replaced on my phone with a plastice seal from the inside of the screen and to its outer part to avoid getting scratches and so that if there's a problem on the screen they can also get the item replaced from their supplier. But how am I supposed to get its quality if I will use it with plastic seal speciall from the lcd how will it work well from its sensors and the colors from its diplay were not as like my original screen. Can I still have it replaced?
Оценка 0
Добавьте свой ответ
Merinia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 2,611
