iPad Air power/lock button doesn't work - very weird!
I have an iPad Air Wifi 1st gen for screen repair. According to customer, the power/lock button worked fine before. I smoothly removed the old screen, put on a new screen. Everything works perfectly. However, I notice the power/lock button doesn't work properly. The symptom is very strange, never seen something like this before:
When I pressed power button, the iPad turned on perfectly fine. When I pressed power button again, it won't go to sleep mode. It doesn't matter how long I keep it pressed, nothing happened. The "slide to power off" won't come up. After 2 minutes, the iPad went to sleep mode automatically (because the auto-lock was set to 2 minutes). If I press the power button again, the iPad will wake up. But it won't go to sleep again until 2 minutes passed. If I press and hold the power button and home button at the same time for a few seconds, the iPad will soft reset and restart as normal.
I thought the power flex might have problem, then replaced it with a known working power flex. But it made no difference! The power button can only wake up the iPad, but it can't put it to sleep or turn it off. I reset the iPad (haven't restored it yet, just reset) to original factory setting, again made no difference!
Any help will be highly appreciated. It almost drives me mad!
Это хороший вопрос?
