What is a good inexpensive Ram Tester
we work with 8500s, 10600s, and 12800s 204 pin ram pieces, and we're looking for a good testing unit that can test 1 piece at a time to see if it's working, and also to help identify mis-labeled pieces of ram or unlabeled pieces of ram.
i found a few units for around $3500, but we're not looking to spend that kind of money as we don't have that much mis-labeled untested ram. does anyone know a reliable inexpensive unit that would work well for this?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Have you considered using an old laptop with MemTest86? That's what I use to test ram, and it's a cheap option. I just have one plugged into an external monitor and I keep the rear panel permanently removed.
- Jasen
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
thanks.... i'll look into that
из
Добавьте свой ответ
dollartripclub будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 11
За всё время: 77
