Audio Channels not playing Correctly (Broken 3.5mm)
I think I may have a broken 3.5 mm port headphone-side. If the plug is fully inserted and twisted a bit, the audio plays quiet in both speakers, but one channel is significantly harder to hear. If the plug is pulled out just a bit, but still holding in tight, it works like new. Any help? Beats Support said $100 for replacement of these 6 year old headphones [BTW, these are green Beats Solo HDs (Serial Number J4112)].
Это хороший вопрос?
1 Комментарий
Krishna Reddy you have tried a different cable to the headphones?
из oldturkey03
