UE Boom 2 speaker broke after being in water
Completely made sure all of the ports with sealed shut and proceeded to use my speaker for the first time in the water. DID NOT COMPLETELY SUBMERGE IT, it was probably in about 1 in of water for 10 minutes when the speaker shut off.
It will not work anymore.
Was advertised to be waterproof for up to a half-hour in about 1 meter of water?
Это хороший вопрос?
4 Комментариев
There are some limits here! It's not really intended to be used as an underwater speaker only survive a dunk turned off. {https://www.gizmodo.com.au/2015/09/ue-bo...|UE Boom 2 - The Best Bluetooth Speaker Is Now Waterproof For The Same Price]
из Dan
Dan , unfortunately I do have the UE BOOM 2, which is the water resistant one. Advertised to be able to work in 1 meter submerged for 30 min.
из [deleted]
Hi Nicole, the same happened to my it boom 2. It was submerged partly for barely 2 minutes and it hasn't turned on since. Did Logitech help you out?
из Ernest D'Souza
Similarly I left my wonderboom a float for bearly 1 min and after doing so it makes a static noise as if water had entered the speaker.
из Jose Javi Moya-Angeler Garcia
