Information and repair guidance for the GE Profile PSS23NGS, a side-by-side refrigerator without ice-through door feature, made by Leiser S de RL de CV, introduced in 2008. This page covers information for model numbers matching the pattern PSS23NGS***.
1вопросов Показать все
ice maker not working ge profile fridge
I have a GE model PSC23NGSA WW and it appears that the ice maker stopped working and resetting it did not work I noticed that the water is not supplying the ice maker. Any advice?
Это хороший вопрос?
Оценка 4
1 Комментарий
The green light is not lite either do I need to purchase a new ice maker ? I have tried resetting it , control arm moves freely, checked connection seems fine. Any other advise ..
из
Добавить комментарий
3 Ответов
Выбранное решение
- Before you test the ice maker - make sure you have sufficient water pressure, and that the fill tube to the ice maker is not frozen over like the above response says.
- If it is frozen over, I would suggest again checking the water pressure - but changing the water valve either way. This unit is about the age where the valve can start to drip, also causing it to freeze.
- If you DO NOT have a frozen fill tube, test cycle the ice maker to see if it will fill. If you aren't handy with a multimeter, you can just hold your hand on the water valve in the back as the ice maker is cycling. You should hear a humming sound and feel a vibration on the valve for 4-7 seconds towards the end of the cycle. If the ice maker completes the cycle without calling for water - change your ice maker.
Был ли этот ответ полезен?
Оценка 6
2 Комментариев:
From what book did you get that image?
из
is there anything electrical that should keep the water outlet into the maker tray from freezing?...or is it the fault of a leaking valve? THX.
из
Cause 1
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Оценка 5
If you have a filter pull it out replace run it you will have water after you have water then insert nee filter be sure to run water dispenser couple of gallons to get all the nasty out , but to your ice maker you have to kick it in n the cycle just look for your model and Google/ YouTube how
Оценка 0
Добавьте свой ответ
Walter Harkins будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 18
За последние 30 дней: 109
За всё время: 47,344
