Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Signal just searching even with/without sim card
Hi im andy from indonesia
I buy a iphone from my friend that he said broken, and i just wanna repairing by myself. This iphone just on the first setup on "Hello screen" that i cannot activate to enter homescreen menu.
The problem is when i turn on iphone keeps on signal "searching..." even with/without sim card. I believe that problem maybe because the time has wrong, the time showing on utc -7 but my location in indonesia on utc 7. I can't correct the time which i cant enter to the homesreen menu, and i cannot restore/update always stuck on "waiting for iphone".
Please anybody can help me?
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
Наиболее полезный ответ
This question seems to be a similar enough problem that the solution might work for you: iPhone 5 won't activate after factory reset.
To save you some scrolling, here's the solution I think will help:
"Here are the steps I took to solve this problem (to the best of my ability to explain them)
- Turn off iPhone
- Open iTunes on computer
- Hold down home button on iPhone and plug iPhone USB into computer
-> (Do not plug in USB before holding down the home key)
- Click restore iPhone on iTunes and update when asked.
-> (You want a full software replacement with update)
This was clearly caused by some sort of corruption to the firmware." - ru5ty03
Good luck!
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
I liked the marble machine ;-)
из
Thanks rachel, but i cannot restore always stuck on waiting for iphone..error 4013
из
Have you tried the steps listed on the Apple Support site for error 4013? https://support.apple.com/en-us/HT201444
из
Yes i already try
из
Добавьте свой ответ
Andy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,266
