The Quest went on sale in North America in early 2011 as a 2011 model.
3вопросов Показать все
How can I open and clean my head lamp that is covered with fug?
My front lamps are covered with white fog and that makes my car look very old. Please anyone knows how to open my quest 2012 and what product is best to use to clean it?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Here's my same question on this with a very good answer from @lpfaff1
What causes headlight clouding and best fix
Был ли этот ответ полезен?
Оценка 2
@chy4austin you cannot. Those lenses have most likely lost their protective film because of UV rays from constant exposure to the sun and harsh chemicals. There are plenty of products that promise to fix this issue but none of those will ever really work or replace the protective film. For a proper lasting repair, you would most likely have to replace the headlight assembly.
Оценка 1
Sometimes the fog-look on headlights is on the outside. There are many ways to improve or restore their condition.
Here's a video tutorial on how to improve the situation using toothpaste. He shows you what it'll look like in the very beginning so you can have an idea of how much it might improve the looks. He also mentions that there are kits for sale for $15-20, and they're honestly the same stuff a repair shop would use. I will say that whatever you do, be careful not to get it on anything but the headlights. I used a kit once in an auto shop class and we had a fun time trying to get the polishing/cleaning paste off of the paint part of the car. Masking tape is your friend.
This video goes more into depth on the options for cleaning the outside of the headlights, comparing and explaining as he demonstrates them. At about 3:35, you can get an idea of the range of splash from a DIY kit.
If it is on the inside, here's a video that covers how to clean that without taking the headlight too much apart using magnets and cloth. He actually gets to the cleaning part at around 9:40.
You got this!
Оценка 1
Добавьте свой ответ
Jane будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 249
