what should I look into, and do?
I dropped my laptop about 16 inches onto hardwood floor.....When I turn it on, it makes 3 beeps over and over. The power on light will flash 4 times, over and over. The screen only makes a flash for a milisecond just as it tries to start.
Any suggestions would be most appreciated.
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
First step would be to reseat the memory, 3 beeps is an error letting you know the computer is not reading the presence of the installed ram. reseat it and let us know.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Screen flash can be another indication of no memory detected.
из
Thank you for your response! I waited for lap top to cool. took out batt., opened up memory and removed the 512 mb memory and reinstalled it. Powered it up...no change.
A couple of other observations I made were....the lap top had been on lights flashing the sequence over and over with no screen response for a half hour or so and it was warm. Not unusually hot or anything, but "normally warm" to the touch. I had tried to reset the pram in past attempts and at start up you can hear the hardrive (?) "spin" Like I had a cd in it or something. There is no cd in the cd player but you can definitly hear a SWOOOOSH start-up. I assume the hardrive is working.....rrright?
Оценка 0
3 Комментариев:
I think I got it...comment/not answer.
I did as you said...no difference what can I try or look into now?
из
Open it and look for disconnected cables or loose parts.
Good Luck,
N.
из
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
''' In addition to the beeps, on some computers the power LED will flash a corresponding number of times plus one. The LED will repeat the sequence after approximately a 5-second pause. The tones are only played once.
N.
из
Добавьте свой ответ
randal bodeau будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,271
