Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Wont turn on, computer not recognizing, gets hot
Okay so I replaced my lcd screen back in April. A couple of weeks ago it started to get fuzzy so I thought a ribbon cable might have gotten loose. When I checked to see if all of the cables were connected, I accidentally put a longer screw where it shouldn't have gone...I know rookie mistake. Anyways the phone was still responsive to notifications and was able to be recognized by my Mac. I let it sit and I guess it eventually died on me. I plugged it into the charger and it gets super hot right near the front camera. Even though power is getting to it the computer won't recognize it anymore. Please help
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Long screw damage is not something your regular home repairer should attempt to fix. It sounds like you definitely have board damage. If you post your general location, I'm sure there are micro-solderers near you that can do the repair or at least point you in the right direction to find someone who can.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Christian Bellew будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 40
