Repair guides for Android cell phones manufactured by ZTE.
1282вопросов Показать все
turned on phone to META MODE screen
turned phone on and it says META MODE. i cant turn it off or press anything. anyone had this before or no how to fix it
Это хороший вопрос?
Оценка 19
8 Комментариев
what happens when you pull the battery?
из
It depends on the phone, some ZTE's have a unibody with an encased battery, such as the ZTE Blade V0720 (The model I have)
из
My power button does not work that is why i can't remove it from META mode.
- To use phone normally, press & hold Power button for 10 seconds to restart phone.
Help please. Can't find anywhere to get power button fixed.
из
Hi put on my mobicel r4 went on but only comes on to the vodacom add thingie and doesnt want to do anything trying to switch off for 10 seconds it goes off then put it on and does the same any help ?
из
Thank you so much this is so helpful.
из
Показать 3 больше комментариев
Добавить комментарий
4 Ответов
Наиболее полезный ответ
It's like a halfway between the android bootloader mode and recovery mode, generally to fix it, you would hold the power button down for 10 seconds to force the phone to turn off and then hold the power button to restart the phone
Был ли этот ответ полезен?
Оценка 7
9 Комментариев:
This worked! Thanks a lot. I was panicking as it had never happened before. very useful
из
thank you it work
из
This won’t work for me, although that’s what it says to do on the phone
из
"Huntshu" Casual Gamer !
" Uyindoda ungabisoluka "-(isiXhosa)
из
South African : isiXhosa Translation
"Hurray"-as in Happy ! a celebration hauling to Casual Gamer- for advice.
" you are the man (Uyindoda)..... "ungab'soluka " ( this one is you home work search and know the Xhosa people ) Motherland emzansi
из
Показать 4 больше комментариев
Had the same problem with my son's Mobicel phone. Just opened the back of his phone, took out the battery and switched it on again. It worked.
Оценка 0
Tell me more about mega
Оценка 0
1 Комментарий:
What is the question please
из
Phone was fully blank only showing meta mod
Оценка 0
Добавьте свой ответ
barry salmon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 47
За последние 30 дней: 226
За всё время: 44,180
