Can I replace the charger port?
It will work for 2 minutes while on charger but if I move it, it will shut down. Battery says dead or low, if unplugged doesn't work at all. Is there anyway to fix this?
Это хороший вопрос?
Это хороший вопрос?
First put a new battery in it. While doing so look for any corrosion or bad connections.
Был ли этот ответ полезен?
If doing what @mayer suggested doesn't fix it, it is possible to replace your charger port+motherboard, and it is rather easy. When you're replacing your battery be sure to get a battery with a straight connector, as many sellers advertise iPod batteries as compatible with Zune when the connector is indeed wrong.
Link for a good, proper battery:
https://www.amazon.com/gp/aw/d/B010RH59O...
How to replace the motherboard+attached charger socket: Microsoft Zune 30 GB Logic Board Replacement
Hope this helps!
I have seen this when the battery is past its life expectancy. The battery swap is very easy, and the replacement batteries are plentiful (on eBay). I have done it a number of times!
Is there a way to order a new internal charging port? I still have mine from years ago and have not been able to use due to some of the internal wire charging teeth being shoved in from a bad charger.
All help appreciated!
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 1,747
