The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
100вопросов Показать все
pls help me how to fix it.
My Samsung j200 has sundenlly drop and sink in the water and the I turn on in 3days before that happen but when I turn on it was white screen in the LCD and all are fuctioning.... The sound the notification and even a screen shot have heard function so what should I do to fix this pls help me..
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
You need to first get it completely dried up or get it checked cause there could be some moisture etc and could damage electronics in the phone if you continue to use it , the problem with the White screen could be the digitizer failure.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Tnx I appreciated your comment.
из
The didgitizer is what senses your touch. It would not affect your display.
из
Completely cover the phone in a covered container of rice for a couple days to remove all moisture. I have read this on other sites it may or may not work due to how long the phone has had moisture.
Оценка 0
1 Комментарий:
Rice is actually bad for your phone. If you just want it to dry, let it sit for a long period of time. The only problem with drying it, is it will start corroding. WATER+AIR=CORROSION. Corrosion will eat away at the phone continuously.
из
Добавьте свой ответ
nickroms ferrer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 165
