Why my iPod turn on appear the apple but shut down
One day I charge my IPod touch, and well appears the baterry indicator, but 30 sec later turn off, I unplug and plug againg to the charger, but appear the apple, like when I turn on , and later shut down or the screen is totally in black.
I try with diferent charger but doesn't work , and later I connect to my computer and the same happened.
Please let me know some what I can do ??
thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Try plugging it in and leaving it over night. If it still doesn't charge, you might need a new battery.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Vernon, I would think that if you start with what iTronicsRepair suggest, you are getting it going again.
из
it happens when your battery is very low keep it blinking until it charges normaly.
из
It is a good answer but pretty much the same as above. Good job so and hope to hear more from you....
из
Добавьте свой ответ
vernon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 751
