The Huawei Honor 8 is an Android smartphone released in 2016 that features a 5.2-inch 1080p display, 4GB of RAM, dual 12MP camera sensors, a fingerprint sensor, and a USB Type-C port. Model : FRD-L04.
Вопросов 20 Показать все
Phone won't turn on after drop.
My Honor 8 won't turn on after drop. Only red LED lights while it is plugged in charger. Can you help me ? Phone is on first sight not damaged. Could it be display issue or some pins inside just disconnected? When I connect it to the PC it shows up and disconnect and this repeats.
Это хороший вопрос?
Оценка 1
1 Комментарий:
I have the same problem but when i press the power button for a long time it shows "Honor" and it dies again the screen lights up for a second
из
Добавить комментарий
Ответов (2)
Hello! An unprotected drop to a phone is likely fatal to your beloved device. Luckily, by your description, it only appears that your display and display and connection components are damaged. You can easily get this repaired at a professional repair shop.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
So I need to replace whole display? %#*!^@. Thanks for your reply
из
It sounds like a component of your LCD display was damaged from the drop. I suggest replacing the LCD display on your device, which you can do by following this guide.
Оценка 0
Добавьте свой ответ
Timotej будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,122
