Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
How do I know when the logic board needs to be replaced?
I tried replacing my 5s screen with a sceeen i bought online but it seems it didn't work and now I'm wondering if it was a bad idea, i can't see anything on the screen when i try to turn it on, its veey confusing
I really need some help before my iPhone 5s is completely obsolete
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Did you power off the phone and disconnect the battery before removing the old screen and before putting the new one on? You can troubleshoot it by 1. seeing if itunes still sees it. 2. If it does, use a flashlight and point it at the screen when on to see if you see a faint image (If so, it;s a blown back light circuit 3. you can put your old screen back on to see if it works to know if you got a bad screen. and last, did you put the screws back in the same holes you got them out of around the LCD Shield? You can cause damage to the logic board with the wrong screws (Long screw damage). Write back and let us know what you find :) Good Luck!
Был ли этот ответ полезен?
Оценка 2
screen not working after a replacement? there are plenty of causes for it.
Before starting, look for the following;
- All connectors are in tact. (no tears, disconnects, and clean)
- The battery is re-installed. (commonly the battery gets left unplugged on home repairs)
- The computer reads the device. (plug it in, itunes should recognize it as a locked device)
- There is no physical damage to the board. (scratches, missing/chipped components, etc)
1) Start with a redo. Open the device, Disassemble it as needed, and reconnect everything. something may be causing issues.
2) try a hard reset. (plug it in, and hold the power button, and the home button for a minimum of 15 seconds) see if you see the apple logo.
3) if this doesnt work, you could have a backlight issue. Shine a flashlight onto the screen and see if you can get a dim picture. if you see the outlines of your background, then you may have a backlight issue. in this case, start by trying to resolder the three connections on the top of the back of the screen, that leed to your backlight.
4) should these not be the case, you could have a bad screen. it happens often. at my store, we always try three before moving forward with other possibilities.
5) this point forward, you are likely looking at a board level issue. boards are usually not worth replacing, but if you can reflow some components, you may be able to get it working again. set your hot air rework nozzle to approximately 300-325, and airflow to medium. heat up the board localized around the screen connectors and see if the connectors are working.
Оценка 0
Добавьте свой ответ
Curtis O'brien будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 166
