Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412вопросов Показать все
There something wrong 3Ds Xl speaker ribbon
So I recently fix my 3Ds XL for my little brother and he dropped it a month after. So after I opened it up and did a System check I found the speaker wire that were connected to the speaker ribbon are ripped out. Is there any way I could fix this by soldering them back together
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi!
You can totally solder that back on there. You can have a really good look at this picture to kindda see what goes where.
However that ribbon looks beaten up to me, I'd replace that entirely.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Do you think it's the ribbon that was causing the problem or should I just try to use the ribbon and if it doesn't work get a new ribbon
из
I mean I don't know that the problem is in the first place other than the fact that the speaker broke of since you forgot to mention it.
Yeah, I'd only get a new ribbon if I'm sure this one does not work properly...
из
Добавьте свой ответ
Nic будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 367
