Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
iPad mini 2 won't charge
My iPad fell off the bed while charging, bending the Lightning connector slightly, so that I had to prop the cable up on something before it would charge.
Now, though, it has gotten worse, to the point of hardly charging at all.
Is there anything I can do to remedy this, short of replacing the logic board or doing microsoldering?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
[] try another cable if they work...
[] if the pins have been damaged but workable, try something like a "magnetic usb charger" for Iphone/ipad, they're cheap and they snug fit into the device's port and wont have to be removed at all.
It helps if a little movement/or angular variation in your charging cable causes the charging issue.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Oh wow. I had no idea that existed. I'll give it a try. Different cables don't help, but perhaps this will. At this point I have to wiggle it to get it to register a connection at all, and it won't connect consistently. I'm pretty sure I bent the connector somehow, but I'm not quite sure what is damaged.
из
yeah give it a try and see if helps, otherwise you'd probably have to replace your connector . thanks
из
Добавьте свой ответ
Calion буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 212
