The Atari 2600 or Atari Video Computer System (VCS) is a video game console released in September 1977. The 2600 runs a MOS Technology 6507 CPU and uses ROM cartridges for storing games.
32вопросов Показать все
What kind of cable is This?
This cable is for my Atari, but I need another one for my Sega Master System, i wanted to know what the cable is called. People call it a RF Input, but for some reason the cable is not called a rf cable so I don't know how to search up this exact cable
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@krisow those are RCA cables
Update (11/11/2017)
You can still use the RCA cable. Check on here or on here for a replacement
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I've searched that cable up on Ebay and its not the right cable sadly, they're very alike, but not the same
из
It is called an RF video cable. You can find them on Amazon just look up the term RF video game cord or cable .
And RCA cable would be a temporary fix. However you would get a little bit of a loss of signal because of the make up of the center core of the wire, it is a little thicker and has an 8 ohm impedance. The RCA contact on the outside is a little thinner as well versus the thicker contacts on the standard RF cable.
Оценка 0
Добавьте свой ответ
Krisow будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 864
