The Philips Norelco Shaver 3100 is an all-in-one styling trimmer. It has multiple attachments for all your grooming needs. It is identified by model number QG3330/60.
Can I get a replacement for the standard blade/razor?
My Norelco Multigroom still working great, but I have problem with the main, wide blades on this model.
The blade wont stay in it's location. Usually you'd insert and turn and the head is locked in. My blade doesn't "lock in" and when this is turned on, the blade eventually is shaken loose and then won't work.
The smaller blades stay locked in with no problem, so it appears the problem isn't the main section.
I've looked online but can't find anything about obtaining a new blade.
Это хороший вопрос?
Счет 0
1 Комментарий
Where can i get the blade i live in ocala fla
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Philips does sell accessories for this.
https://www.usa.philips.com/c-p/QG3330_4...
Is that what you are looking for?
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
very close, but no cigar. Thank you! I looked around that site and the trimmer I need is wider that the one displayed. I do have the 3300 model, but when I looked around the site and it does not appear that the main/wider trimmer I need isn't there.
из
Добавьте свой ответ
phillyfrog буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 1,001
