Why is my laptop alternating between a grey screen and normal display?
Every second and a half it will switch between normal display and a grey, fuzzy screen. This includes when my laptop is starting up. Apart from this it seems to be working perfectly.
I'm thinking it might be an issue with the graphic's driver but I've had a look and it seems that there are no updates available for the driver and it hasn't updated recently, so I don't really know what is going on
(Edit: I have an Acer swift 5, and have only had it for 2 days)
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It is possible that the display cable that connects the screen to the motherboard is damaged. You could possibly repair it yourself, but if you have only had the laptop for two days, then return it to the store and get a replacement one!
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I agree it sounds like a loose cable or motherboard damage. I also agree since its so new, go exchange or return it. Don't repair it yourself.
из
Добавьте свой ответ
Cosmik Shadow будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 501
