First unveiled at the 2005 Frankfurt Motor Show, The Audi Q7 is a seven-seater, three row, mid-size luxury SUV manufactured by Audi.
Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
it was the ecu got water damage dont know how but it did
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
How did u find out it was your ecu?
из
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
из
Life saver!!!!!!!
из
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
Счет 0
1 Комментарий:
after having accident (a crash) with my Q7 it stop and didnt crank again. any solution?
из
Добавьте свой ответ
carlos буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 55
За всё время: 4,057
