Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Keyboard light not working complete, only in the middle
The 'backlight' to light up the key's on my keyboard is not working complete. In the middle it is strong, on the left and right side it's almost not visible.
Changing the settings did not work.
What can I do?
Это хороший вопрос?
Оценка 1
1 Комментарий
Did anything happen before this occurred? Or did it just happen one day? Was any liquid ever spilled on the keyboard or any service done to the laptop recently?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
You're getting light, so your backlight is working. The led's behind the keyboard are wired in series, so the circuit itself seems to be fine.
So it would seem that the thin sheet of polycarbonate that diffuses the light and spreads it across the whole keyboard has either gotten misaligned with the side-emitting led's, or, something is blocking the light from the led's from entering the medium.
You could try turning your laptop upside down and flushing whatever debris might be stuck under the keyboard with a can of compressed air. (Though I can't imagine how it would have gotten there in the first place)
If a liquid spill is the cause, it would have to be some kind of opaque liquid (milk, coffee, etc.), and you could try to take the whole backlighting sheet-assembly off the keyboard. It is attached with adhesive. Be warned that you can very easily snap one of the smd led's that are on the circuit in the middle, which would destroy the whole thing in the process. They are very fragile. If you can manage to get the backlight assembly off, you can just wash it in running water, as long as you wait for it to dry completely before reassembly. This will activate several water damage indicators that are on the reflector sheet, though It isn't really an issue for a model this old, unless it is part of an enterprise/business program.
Easiest thing to do would be to just get a new keyboard backlight assembly from amazon/ebay/wherever for about 15 bucks. You will still have to gut the top case almost completely to make the replacement, but it's a whole lot easier than trying to clean the old assembly without snapping one of the led's.
Был ли этот ответ полезен?
Оценка 1
Cover the area near the camera (this is where the light sensor is) and press the F6 key again. It should work now.
The reason why it isn't working in areas with natural light is that your computer KNOWS you don't need it. To change this, so you look super fly with your lit up keyboard, (and unnecessarily drain your battery) head on into your settings, and uncheck the selection that says "Adjust keyboard settings in low light". Then you can look super cool at Starbucks drinking your tea latte with your lit up super fly keyboard, in the middle of the day.
Hope this helps!
Оценка 1
1 Комментарий:
I would have to disagree, the backlight being on in the middle of the keyboard indicates that the LED loop is on. Though it is a simple enough test, can’t hurt to try it I guess.
из
I had a similar issues with Macbook pro Keypad light not working complete, only in the middle portion. Best solution is to alignment of backlit if led's are in working state. If there are 6 led lights, also there are 6 tiny hole on transparent layer of backlit which illuminate the lights to the whole keypad. Just align the LEDs into the tiny holes and install on the keypad. Without any hassle it works great. It's 100% solution for the above thread.
Оценка 0
Добавьте свой ответ
Jean Paul van Hoorn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 20
За последние 30 дней: 98
За всё время: 9,307
