Battery operated RC truck designed for rock crawling and off-road terrain. Made by Maisto Tech.
17вопросов Показать все
Can the truck be tested or powered on without a remote?
We bought a used truck at a thrift store, and it didn't include a remote. Before we invest in a replacement of the remote, we'd like to test the actual truck to make sure it works. Is there any way to test the vehicle without a remote, such as turn on the motor?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Yeah, you could theoretically wire up some batteries to the motor if you can access the main circuit board and see in it does anything. While I don't own this this thing personally and never tried this, I don't see what could go wrong. Just be sure to wire the batteries/ power source up properly and avoid applying too much power.
PS: This will also be helpful.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
EJ M будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 123
