Ok so i found somewhat a solution to this problem. It is probably not the ideal solution but it alteast will keep your laptop from falling apart for hopefully a good while.
As you can see in the following pictures i had this exact same issue
So what i did to 'fix' it was to use 2 washers and 2 midlong laptop screws.
Then the idea was to simply put the washers on top of the base and screw the screws in, in this way using the base itself as support for the upperside of the laptop.
I then realized on one side that screw hole itself it actually also broken off and somewhere being loose in the laptop, i managed to get the broken pieces out of there.
So if your screw holes itself are intact you can just use something like the screws you can see in the picture above, this also worked on one side of my laptop, but since on the other side the screw hole itself is broken off, i decided to use a bigger screw and use the metal plate inside the laptop itself to screw it in.
This is the result:
And as you can see, it is holding together right now, and will atleast keep the laptop from falling apart for now.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
5 Комментариев
Hi!
What happens if you just press on the plastic top cover until it clicks in place? Does it stay like it should or not?
из Alex Niculescu
Hi. I have that problem with my G570.
I have no problems with the functions of the laptop. But i wish i knew what a new casing would cost as the hinges are metal but holding plastic together.... in my case, chipping and cracking the rest of the laptop. Is there anywhere i could find a place that will give me a new/used casing?
из melgdav
You can see the official site of Lenovo where you can find the parts you want to buy according to the laptop(Even body can be bought) . Login and check out! Else go to the Nearest store of lenovo.
из Kalicharan Mohanta
Hi! Melgdav you can search in Ebay for the parts you needed for fix your computer using your computer model number or serial always verify well the photos to be sure that they are the correct parts if you like follow this link:
https://www.ebay.com/itm/New-Lenovo-G570...
из dxgraph
@nathairglas, i beg pardon, but i must ask what was the price of this machine, when you've bought it?
из Me The Gorgeous
