A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239вопросов Показать все
Can bevel above hinge be replaced easily
i have Macbook pro with touch bar Model A1706
The bevel above the hinge (where it says Macbook Pro) has hairline cracks Think might be a issue using a laptop protective cover
Can it be repaired ??
Update (11/30/2017)
Thanks for reply
Ho much to repair ?Do you think a common problem?
Think damage caused by Macbook hardcase shell
see picture attached
looks as if when closing lid causes a pinch point because case clips on back by hinges
Do you think Apple would cover under warranty ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I believe what you're talking about is the clutch cover. It can be removed as illustrated in Step 3 of the Retina Display Teardown. You'll probably have to remove the display in order to be able to remove it. For that, you'll have to do some disassembly. You can follow the Touch Bar Teardown, you don't have to remove everything, like the touchpad and battery, it shouldn't be too difficult to figure out what needs to be removed and what doesn't.
At the end of that teardown is a link to another teardown where it shows how to remove the display from the chassis. Be aware that unlike some of the older MacBook screens, this isn't one isn't entirely self-contained. Some of the display electronics are now housed in the bottom assembly.
In my opinion, it's not that difficult a job, but an awful lot of trouble to go through for what is just a hairline crack.
MacBook Pro 15" Retina Display Mid 2012 Изображение
Инструкция
MacBook Pro Retina Display Teardown
Сложность:
Модерировать
MacBook Pro 13" Touch Bar Late 2016 Изображение
Инструкция
MacBook Pro 13" Touch Bar Teardown
Сложность:
Модерировать
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Dav будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 550
