Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
583вопросов Показать все
Progress bar on start up screen stuck and screen is frozen.
When turning on my computer, the progress bar on the white startup screen with the apple logo in the center, gets stuck 3/4 of the way and the screen freezes. I tried option-command-p-r and was not successful. Thanks for your help!
Это хороший вопрос?
Оценка 2
2 Комментариев
I had a ѕіmіlаr issue, when turning on my Mасbооk Prо used to freeze.
During startup the progress bar would get stuck.
Fіnаllу I mаnаgеd tо rеѕоlvе thе рrоblеm.
Follow thіѕ ѕоlutіоn hеrе: http://bit.ly/MacBootStuck
Hоре thіѕ hеlрѕ
из
The link provided above for its solution does not work. Please kindly update.
из
Добавить комментарий
2 Ответов
Выбранное решение
That's about where the GPU driver kicks in. See if it will boot in Safe Mode (hold down the Option key On start up). What OS X are you running?
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
We are not sure...
из
OK, what did it do in Safe Mode?
из
While it is in Safe Mode, you should also run Disk Utility and run "Repair Permissions" if it exists, and "Repair Disk".
из
I ' ve done it. But it doesn't work
Mise à jour (13/01/2018)
Wath's the next step. Please. Thanks for helping
Оценка 0
Добавьте свой ответ
Kathy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 44,951
