Charging Cable tip stuck inside port, need help
Hi,
the tip of my charging cable broke and is stuck inside my ipad. I have tried the safety pin tip but all my safety pins instantly bend. I have dug a little bit of the white material in the middle of the broken part out but I am unable to get it out. Any tips for getting the tip out of the charging port? When I took it to the store, they said I would have to replace the entire ipad.
Это хороший вопрос?
9 Комментариев
Replace the entire iPad for that little problem? That’s probally one of the most ridiculous things apple has ever said! Anyway, could you include a picture to see what we’re working with?
из Aiden
Hi, I've edited it to attach a picture. As you can see, I attempted to drill a hole in the middle of it but all that happened was that I got a hole. I have been unable to get it out of the port.
из Monica S
Do you have tweesers?
из Aiden
Nothing small enough to fit inside.
из Monica S
I have heard that you can put super glue on the end of the plug and reinsert and hold until it dries and then remove the piece. Have not tried yet.
из kovacscolleen
Показать 4 больше комментариев
