Cost of my blu vivo 5r screen replacement
How much would it cost to replace my blu vivo 5r screen and where can I get it done in Lagos, Nigeria
Это хороший вопрос?
Это хороший вопрос?
Based on my research, they say it is recommended to replace the full LCD and touch screen digitizer. While in theory it is possible to only remove/replace the top glass, there is a good chance the LCD underneath gets damaged while removing the glass.
That said, the BLU vivo 5R glass is available on amazon for under $50.. check this out
The local phone repair shops in the neighborhood mall should be able to help get this fixed. Their labor charges are around $60
Disclaimer: I haven't yet bought the digitizer or gotten it fixed, will do it hopefully soon...
Был ли этот ответ полезен?
how do u get to the back of the phone I tried to replace the screen but there is a metal plate preventing me from disconnecting the screen connectors from the phone if u can help me my email is myronsna@gmail.com
I removed the the back its not hard just use some steady force after that remove all the screws then being careful of the battery cable remove the battery from the bottom might be tight but dont worry just take your time after that heat the front to remove the adhesive that should be it hope that helps
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 1,409
