Flashed wrong recovery,got into boot loop
I cant get into the recovery mode.there is nothing working in my tablet.when i power on it will show the mediapd logo..then stay on that screen and switches off automatically ...is there something i can do?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
there is a high likelyhood the device is bricked if you cant reaccess the download moad. in order to fix a bricked device, you would need to buy a Jtag, and flash it with that.
your cheaper option would be to send it to a shop that already has one, and the ability to use it.
Был ли этот ответ полезен?
Оценка 0
If you flash a wrong image into the recovery partition, you must try to start into the fastboot mode.
I believe the adb device driver is still on the PC available. After connect, you can reflash the recovery via
>fastboot flash recovery <image. name. of the right recovery>
which is in the best case in the same directory as flashboot on your PC.
Оценка 0
Добавьте свой ответ
kannan rajan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 1,412
