E100 Code on start up and wont apply Update
Hi, I've got an issue with my Xbox One console. when I turn on the Xbox it doesn't give me the start up green screen. It goes straight to something went wrong and gives me a error E100 code. I was wondering is this a Hard Drive Issue? OR a Disk Drive issue. I really don't want to buy a new Xbox. Hope someone can tell me the issue thanks in advance.
Это хороший вопрос?
10 Комментариев
If you are still having this issue I just fixed mine. I removed the hdd from the xbox and hooked it up to my pc. Accessed the system update 1 partition and deleted all the files and reinstalled the hdd. Then took a flash drive (any drive over 8gb will work) and formatted that to NTFS and extracted OSU1 to it and inserted it into the USB port on the xbox. Booting the xbox by holding for 15 seconds, the bind button on the side and the eject button and pressing the power button. The console then fully went through with the system update. Afterwards i just had to redo the initial setup but all my games and saves were still there. Hope this helps someone else.
из Justin Wedel
justin wedel buenas tardes ami igual me aparecio ese error asta compre otro disco duro y me aparece lo mismo entonces tengo que hacer todo lo que acaba de decir osea formatear desde mi pc el disco duro ? y luego conectarlo a mi xbox one y poner un usb con el osu1? contesteme porfavor
из torres kevin
How would I go about hooking up the HDD to my PC . I already removed it from my xbox?
из Jake Gazura
Hi jake, you should be able to find a cheap usb dock under 20 bucks on amazon or eBay that would allow you to easily hook it up to your PC. If you don't want to do this you will have to install it in your PC as a secondary drive.
из Casey Boblewski
Great thank you
из Jake Gazura
Показать 5 больше комментариев
