2.26 or 2.4 GHz / White plastic unibody enclosure
645вопросов Показать все
Вопрос закрыт
Change screen of mac but the lower LCD is dark with shadows
I changed the LCD screen of my MacBook model A1342 bought in September 2010
I successfully receive the panel, but once installed correctly by entering the appropriate video connector lights up the screen with no problems.
Unfortunately the bottom of the screen (with a height of 5cm) has many shadows black and white then that ruins the image. Also the screen brightness appears to have very low even at maximum brightness level.
I therefore ask you how I can fix or if it is possible to have a new screen.
My old monitor was the Samsung, but the new one is LG
How can I do? If you want I can post an image of screen!
Thanks
Bye
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi! iFixit will send me a new LCD panel! Thanks lot for good support!
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Contact iFixit here: http://www.ifixit.com/Info/contact
Request an RMA number, return the screen and get a replacement. Try to get the same model number as the one you removed.
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Hi
Ok I have contact iFixit! I'm waiting an answer! Thanks lot.
из
They may be closed till Monday.
из
Or maybe Tuesday as Monday is a holiday. +
из
Hi!
ok thanks for information :)
из
Is the replacement LCD new or used? It sounds like the replacement LCD is bad. I've bought used LCD's on ebay that were not good.
What was wrong with the old LCD. Is good enough you can put it back in and see if has the same result?
I have a spare LCD for an A1181. Let me know if you need it. We can check compatibility.
Оценка 0
1 Комментарий:
Thanks for the reply
LCD is new and I bought it in the appropriate section on this site.
I also reinstalled the old LCD, but there are no shadows and the brightness is also much higher than the new one.
Is possible to have the replacement of this screen? I really think it's a manufacturing defect.
Thanks
It looks like the new screen
http://img64.imageshack.us/i/foto0282d.j...
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,328
