Released November 1998, identified by model number HKT-3020.
28вопросов Показать все
Disc stops spinning when lid closes
Once I close the Dreamcast, the game stops spinning and therefore won’t read/play discs. But if I leave it open just a tad it spins fine. Just stops spinning when I close it. System turns on and stuff fine too. Any suggestions? No one near me whom I have asked so far will repair old video game consoles anymore.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Could the lid be putting too much pressure on the disk when it closes? Does the lid seem misaligned from the rest of the chasis?
из
Добавить комментарий
1 ответ
It sounds like the door open sensor may be damaged. There are ways of tricking these sensors so that the device thinks the door is always closed.
You can see the door sensor in this guide, it's at the top right of the green PCB, in step 6, just above the two green wires and white connector.
Sega Dreamcast GD-ROM Replacement
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Tony Gemba будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 1,122
