The Motorola DROID MAXX is the successor to the Motorola DROID RAZR HD.
Shows charging but then says isnt charging
I replaced a customers screen and battery on their Droid maxx 2 and now the phone shows the lighting bolt saying the phone is charging but when I go to the settings and go under battery it states that the phone is not charging and the battery percentage is not moving, can someone please help me with this issue? PS I removed the wireless charger per customers request
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
there is a possibility that the port isnt transferring the current properly. i would suggest replacing the port, to see if that works.
however, you could have a board failure, or software corruption as well. a factory reset would fix a software corruption.
Был ли этот ответ полезен?
Счет 0
If it wasn’t the battery that is busted then it means that you are using a power adaptor that is not giving enough power to charge it. I do hope that the phone is currently is working! Sorry if I came in way late.
Счет 0
Добавьте свой ответ
cellphonebuyer1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 237
