Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745вопросов Показать все
Messed up colors on external display
When I connect my MBP through a minidisplay to vga adapter to my external vizio 26" monitor the colors become messed up. Black is green or blue and there is general static on the scree. How do I fix this?!?!
Это хороший вопрос?
Оценка 2
3 Комментариев
Can you provide the model number of the Vizio?
из
corrected spelling on title of question.
из
Well done David, as long as you didn't remove the u from colour
из
Добавить комментарий
4 Ответов
Выбранное решение
Yesterday, I went to the apple store and bought a mini display to VGA adapter and now it works great. So, I think that it was the adapter but thanks for all the help I really appreciate it!
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
I find this happens when the plug isn't properly secured sometimes. But I am sure you have already tried that by now....
Try another monitor if you can and see if you get the same thing.
If you see this happening on other monitors, then you want to figure out if it's the adapter or the actual mini-display port on your computer.
If you have access to another VGA > mini DP adapter, then absolutely check to see if you can cancel out the adapter as the problem.
Component isolation is your first step. good luck!
Оценка 2
2 Комментариев:
yea thanks thats great advice I tried doing these things, but sadly I have a vga adapter and no other monitors take that input... thanks though!
из
Glad it was the adapter!
из
Try the moniter reset button/Degaussing? Wiggle connections?
Оценка 0
Make sure your monitor's settings are set to RGB and not something like YPBPR.
Оценка 0
Добавьте свой ответ
grey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 4,657
