Why is one of my propelers is not working
Every time I turn my drone on one of the propelers won't work
Это хороший вопрос?
Это хороший вопрос?
Do you still have it?
There is a screw that goes through the propeller and the shaft, on the bottom gear you have the same set up. the screws will shear in the shaft preventing a simple replacement. You may have to drill out to free the broken screw inside the shaft, through the top worked for me
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 350
It could be the screw that holds the propeller to the shaft; sometimes the break
из lild.james
