The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256вопросов Показать все
weird transparent glitches on my note 4 screen, how I can fix it?
I have sprint galaxy note 4 (sm-n910p) that works successfully, but with one problem. The problem in the screen that splits to normal part in the top and transparent glitch part in the bottom. I don't know the reason of this glitch and I need your help please to remove it..
I try the following solutions but they don't solve problem:
1- I added new original stock firmware... and the problem still same..
2- I did a hard reset... and no change..
Please anyone help me?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I'd test it with another LCD, if the issue disappears then you know what caused it.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Many thanks for you. Your answer is highly appreciated.
из
Its a long time ago..
I get sometimes the same. Today 3 transparent screens over each other. It went away after 5 mn.
I made a screenshot of it but it is not to be seen at all!
If you look good the 'sheets' are a bit trembling.
Got the feeling to be hacked...!
No clue what to do.
Оценка 0
Добавьте свой ответ
huss biohuss будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 179
