puedo instalar windows 10 en samsung chromebook XE500C13-K03US?
Это хороший вопрос?
Это хороший вопрос?
Si, se puede.
Yes, it can be done.
Mira aqui.
Watch this Video.
Был ли этот ответ полезен?
no he podido instalar windows 10 en mi samsung chromebook XE500C13-K03US?, como puedo hacerlo.
I dont know but take a look at its specs and you will find they are short for having Windows 10 running. Specially that one about disk storage (16 GB). https://gadgets.ndtv.com/samsung-chromeb...
What is needed to be done before installing window on Samsung chrome book
If you have an arm processor you cannot. If you don't you must first enter developer mode as in this video then you can install windows from a bootable usb stick, if your system meets the minimum requirements. Windows 10 for example can be installed as in this video.
greetings install windows 10 in a samsung xe310xba and I have problems with the sound card of the rest everything is fine if you can help me I would appreciate it
За последние 24часов: 5
За последние 7 дней: 13
За последние 30 дней: 51
За всё время: 9,099
2 Комментариев
que se necesita para instalar windows 10 en mi chromebook samsung xe500c13
из bob
me puedenenviar un manual de instalacion y los pasos a seguir para instalar windows 10 en mi chromebook samsung. gracias
из bob
