This digital camera was announced by Panasonic in January 2014. The Panasonic Lumix DMC-ZS40 has a 18 megapixel sensor and built-in GPS features.
8вопросов Показать все
Panasonic Lumix DMC-ZS60 will not power up
Hi. Camera got slightly wet on a boating trip and would not turn back on. Pulled the battery and tried to charge it but no response from the camera. Would the water have killed the battery? Or is it something inside the camera?
Don
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
The water shouldn't have killed the battery, but if it wasn't removed as soon as possible after the camera got wet then it may have caused electrolytic corrosion in the electronics, or damage due to current flowing where it shouldn't. Disassemble it and clean all the electronics with isopropyl alcohol and you might just be able to recover it. But if the water got into the lens you may have trouble sorting that out.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Donald Cheeseman будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 379
