Первая модель линейки персональных компьютеров iMac от Apple. iMac G3 выпускался в период с 1998 по 2003 год.
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
Это хороший вопрос?
Счет 1
1 Комментарий
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
из
Добавить комментарий
1 ответ
Выбранное решение
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
Был ли этот ответ полезен?
Счет 3
8 Комментариев:
That's modding, the MAC didn't have that built in.
из
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
из
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
из
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
из
Показать ещё 3 комментариев
Добавьте свой ответ
Denny Tuckerman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За все время: 711
